6.0 liter gen III coolant
dmagas
Registered Member
Colorado
Bit of confusion on this. LS swap some do not like dexcool and others say that is what you should run otherwise gaskets get eaten away from green stuff. Other school of thought green is better just need changing every couple year. Anyone have a clue or ran either one and had better luck with one or other....any help is appreciated.
If it's a used engine and dexcool has been ran through it stick with it. If it's a crate engine you can run which ever you want. I used dexcool in my first engine and stuck with it on the crate.
It's when you mix it together it clumps up.
