6.0 LS oil cooler leak. Any service options?
76zimmer
Flyin Rat
Staff member
Moderator
Kzoo, Mi
My brother's 6.0 is leaking up at the oil cooler, and they mechanic tells him its a one piece non serviceable unit. Cooler, hoses, and adapter on the block? all one unit. Is there any other alternatives to replace this leaking bastard?
Mechanic isn't right. The adapter on the block and the lines up to the cooler are one piece, then the cooler is a seperate piece. Chances are, it'll be leaking at one of the quick connect fittings, might need to change an o-ring out.
