Most of the factory recommendations went to the lighter oils for fuel economy. Part of the reason it worked was due to the improvements in oils.
Running that light an oil using oil from 20 years ago would be causing scrubbed cylinders and scarred bearings.
I have only ever had one vehicle that used oil when new. It was my '79 F150. I bought it new, checked the oil at the first fillup and found it a quart low.
I was a little ticked that the dealer had let it out the door a quart down, but poured in a quart and went on.
Couple hundred miles later, it was a quart down again. I took it back, they checked everything, finally just said the rings were probably not seated yet.
It would use a quart between fill ups! They kept insisting that it was OK, so I decided to call their bluff.
It had less than 5K on it, so I just quit checking the oil. Figured it would seize by the second or third tankfull and I would make them put in a new one.
Finally could not stand it any longer, and pulled the stick. It was a quart low...........
Put 200K on that engine, it would blow out the first quart in 100 miles, then never used another drop between changes.
About 100K in, I happened to see a factory recall for that truck up to 1978. It said that up until then, some engines had shipped with the wrong or mismarked dipstick.
The factory procedure was to change the oil and filter, put in the correct amount, run the engine briefly and then check the level.
If it read a quart low, replace the dipstick.
Apparently one made it over into my year.
I did the test, and it showed the wrong stick. I never changed it, just made sure to not put in that last quart.
I made sure the guy who got it after me, and the guy after him knew that. Have not seen it in a few years, so not sure now.
