Lift pump to box filter?Good afternoon!! Looking for the fuel line that goes from the fuel pump outlet to the the valley for a 6.2 diesel. Mine is frozen to the fuel pump. Thanks!!
Yes. I don’t have a picture. It screws in the pump and goes up to the valley then uses a rubber hose to connect to the fuel filterLift pump to box filter?
I have a pile of extra lines and I will see if I can find one. Otherwise, @imiceman44 may also have something in his hoard and is closer to you
I will check to see if I can find one.Good afternoon!! Looking for the fuel line that goes from the fuel pump outlet to the the valley for a 6.2 diesel. Mine is frozen to the fuel pump. Thanks!!
No worries! I was actually able to get the line off today. Took some heat and good old knipex cobra pliers. No need to look for one, I do appreciate itI will check to see if I can find one.
