I used Tygon fuel line I got from a small engine repair shop--it is good stuff and no clamps were needed,you just push it on and it will not come back off the barb fitting,you must cut it off !..
I replaced a few on my 6.2 at least 3 years ago and its still intact..I got 1/8" intended for weed eaters and the guy cut off 5 feet from a bulk spool and only charged me $5..I keep the leftover line in the glove compartment in case another one fails..
My '85 Suburban came with the AC-Delco factory replacement hoses,so far I haven't used them,they were the black rubber OEM ones that need those teeny clamps,that SUCK to install on the rear most injectors ,which was the one that failed on my pickup..
I also got a few feet of Firestone air brake tubing, 1/8" ID that a local diesel shop gave me when I asked them what they used--that stuff is stiff and has to be softened up with a flame before it'll go on the barb fitting,I did use that to replace the rear most line on the Suburban--it worked OK,but I like the Tygon a lot better..
