my 6.2 is real rough to start at temps 20 and below that, it will fire but will wont start it will chug out each pipe, i cycle the glow plugs and she still wont after the 4th try it will run....the glow plugs are new, the starter turns pretty fast and the batteries are both 800cca. any ideas here..? when its warmer it starts right up it only does it when it that cold, even tried the half pedal and when it fires if you play with the pedal sometimes you can get it around the 3rd try...
