6.2 injection pump
RYNO84
Registered Member
Redding
Good evening all! looks like my 84 blazer needs an injection pump, the old girl has been sitting a long time before I bought it and I’m getting absolutely no fuel out of the pump. I have replaced the lift pump swapped over to a cat filter base and filter and I’m getting good fuel pressure at the pump. And I have checked to make sure the shut off solenoid is functioning. This is maybe why it’s been parked so long. Seeing if there’s some good reputable companies out there to get one from. My local injection shop wants $750 to go through the pump and that’s before repairs. Thanks.
Leroy Diesel, Kennedy Diesel and Quadstar Tuning are all good IMO.
Do you get any white smoke while cranking? Any fuel at all if you crack open an injector line at the injector?
Had all the glow plugs out and all the lines loose to each injector. absolutely nothing!!
I've seen the fuel inlet clogged before, but it's also possible the plungers inside the pump are stuck out.
