Spike89Burban
Newbie
ive done a bit of searching and havent found what i needed yet... is there a good 6.2 swap info thread here? if you could point me too it id apreciate it... now... the real question... has anyone ever tried to use an nv4500 behind a 6.2? i know they were used in chevy trucks from 92 on.. but would the bell housing be the same? what would be required to swap this in? assuming its possible.. also, the nv4500 i have is 32 spline, does anyone make an adapter to bolt my 208 tcase to it (32 spline from behind a th400) or will i even need one?
................................................................................................maybe if I decide to retire the 82 K2500 ,I could swap the plates over,and just use the TH400/NP208 from that in the Burb...depends on how long my mom hangs on here--my plow truck will be lucky to make it thru another winter.....once she is gone I will be too most likely,and I wont need a plow truck if I'm not living here....
