I am looking at a 82 K30 with a 6.2. The truck has 92k miles on it and is in great shape but has a problem the owner can't figure out. It will start and run but then randomly won't start. He replace the glowplugs, controller, fuel pump and maybe even the injection pump. Do you have any suggestions or things I should look at? He thought it acted like it just wasn't getting fuel, how do you check that other than cracking a line? I was thinking maybe it is sucking air someplace and is causing the problems.
