Th400??
If you have a TH400 tranny,it might be shifting hard due to the vacuum modulator not getting the proper amount of vacuum from the vacuum pump...my 6.2 has a TH400,and the switch that is hooked in with the throttle cable that controls how much vacuum goes to the modulator was not working right,( diesels have a vacuum pump,which has a constant vacuum--the switch makes this constant source "variable",so it acts just like the vacuum a gas motor would make at different throttle openings)--and my tranny would stay in first gear until 35mph,and slam into second,and it usually refused to shift into third until 50+ mph!...that made city driving very frustrating,and more than once I nearly got pulled over for speeding,trying to get it to go into third!...
I could not find another vacuum switch,either new or used--so I asked a local tranny rebuilder what I could do--he said I could spend 120 bucks for a cable operated modulator,like cars with a blower have to use--or do what he does--run the vacuum hose from the modulator directly to the vacuum pump,and screw the adjustment screw in the modulator(located INSIDE the nipple the hose plugs onto!) all the way in until it seats gently(DO NOT TIGHTEN IT)--now my truck shifts like a caddy,nice and smooth--and almost TOO early...its in third now at 15-20 MPH!...sometimes I pull it down into second manually so it wont lug ecessively....so far,after a long hard winter of beating it plowing,it seems to be hanging in there...hope it stays that way!...
I'm hoping having "constant" vacuum wont cause my tranny to slip or run hot..havent seen any ill effects yet--the tranny rebuilder said not to worry about it,he's done it to dozens of TH400's in diesel trucks and no harm is done...
