6.2 Radiator in a 78 K5 with a Mild SB?
urbnflx
Registered Member
Fremont Ca
Ok, First off... a couple years back I was at summit and found a set of flex-a-lite fans p/n 280(Link) which fit a newer chevy truck/suburban etc. I was able to pick them up really cheap. I tend to drive this truck out in the desert a lot and have had some cooling issues with my mildly modded small block in the past on really hot days with the ac running so a bigger radiator isn't going to hurt. There are no current issues with the cooling system that would keep it from doing its job, but I bought these fans and want to use them because I am sick of hearing the stock fan noise.
The core on my 78 is 28" wide. For this fan setup to fit, I would need a 34" wide radiator. I have searched the net and found that a 6.2 rad from an 82 K5 is 34x19(Link)... which should accommodate the fan's requirement of 34x17" just fine.
What I am trying to figure out is, what radiator supports(OEM/fabbed upper and lower and/or rubber pads) would I need to find in the junk yard or truck parts(LMC or the like) to make this radiator fit. I have seen that I can possibly use a upper radiator hose from a 77 trans am with the 400 in it to connect the upper but what lower hose to fit?
I will be removing the a/c condenser and replacing it with a different style so I will not have to worry about issues with it interfering with the radiator.
you want to make sure that fan spins in the proper direction,newer models with serpintine belts don,t spin in the same direction as the oil v belts.
