I've read some complaints online about the Dorman hose being cheap crap that fails rapidly...some say it was nothing more thasn typical windsheild washer hose,others said they looked just like the GM oem stuff...
Back when my return lines failed,a diesel shop I stopped at gave me some "Firestone air brake tubing" with a 1/8" I.D.--guy says thats all he ever used,you heat it up with a ciggarette lighter for a few seconds and slip it over the nipple..I had no luck trying that,and it seemed awful stiff,like nylon--I decided to go with Tygon instead,after reading online others had used it with sucess..
I looked at the Tygon I put on one of my return lines and after 2 years or so-- it is starting to get hard now,but not "brittle"..
I may put some new tygon on it soon so I wont have to mess with it during the winter..
My Burb's return lines are failing too,the rear most drivers side one that failed on my truck seems to be the first to fail ,being the suckiest to get at...the tygon needs no clamps,I like that a lot..so I should buy 5 feet of it and do both of the trucks with it..I'm keeping a few feet in the glove box too,"just in case"..
