i have 2 low use starters from a gm 6.2 .
both 12 volt style . both include the rear brake bracket to the block to hold the back up so it wont snap the 2 main bolts. 1 has a heat shield for the exhaust also .
1st = duralast a/z dl8402s = 161.99 with core swap .
this is the newer design gear reduction style.
would like to get 75.00 + s/h to you .
2nd = duralast a/z dl8401s = 161.99 with core swap.
this is the older more standard direct drive style .
these are super clean still read stickers on them . both pulled from running trucks I parted out and sold the extra's .
