The 6.2 in my 82 K2500 has started belching a cloud of white smoke bad ,after a cold start,which lasts several minutes until it warms up--also,unless I hold the gas pedal at a faster idle,the engine wants to stumble and stall,and it sounds like it has a few cylinders that aren't firing consistently,the engine sounds kind of like an over choked gas engine-"lopey"-- after it has run a minute or so,long enough that I can let off the gas and not have it stall, it does the misfire/ over rich lope until it warms up good..once its fully warmed up it runs normally..
I know all diesels belch some smoke after a cold start,but it has never done it like this before,nor did it have the other symptoms listed above..
I checked the coolant level,its ok,and the radiator didn't have any excess pressure in it,so I don't think its a head gasket leaking..oil looks black as usual,no mayonaise on the dipstick..
Some other things I noticed today after I put the plow on it (its going to snow here overnight ),I went for a ride to get some gas for my tractor and when I had to accelerate up a long grade,it downshifted into passing gear,took off OK,but then felt gutless,and then bogged down like it was going to die on me..
I let off the throttle and it recovered,but still felt like it was lacking fuel..luckily it did not stall..
When I got to where I was headed,I turned off the engine and then turned the key back "on"--and I listened,I did not hear the electric fuel pump come on..
Usually you'll hear that woodpecker ticking sound..
I know it does not always run,if there is pressure in the fuel lines,it will stop on its own,and only pulse when it needs more fuel..but now I'm wondering if its just that,or if it croaked ..it has been on the truck since I got it in late '03..
I could open the fuel filter drain and see if the pump came on,but I didn't want to get diesel on me--my house already reeks of it thanks to some spilling on my shoes and pants the other day..
This pump is mounted close to the fuel tank and the stock lift pump on the engine is still hooked up also,so its like an assist pump---so if the electric pump died,it may be running off the lift pump alone, and it cant suck enough fuel thru the electric pump with it not on..
I'm thinking it may have a few dead glow plugs--it is the drivers side that smokes the most,hardly any comes out of the other bank..(and that side I know has a dead glow plug I cant get out,been that way since day one)..truck fires right up OK,you don't have to spin it over much--but I haven't tested the glow plugs yet..
Question is,would a dead glow plug make it smoke that bad after a cold start?
It would have to be putting a lot of unburnt fuel into the exhaust manifold I'd assume..
Another issue too--the other day when I filled the tank up,the pump at the gas station was pumping very slowly--it took over 5 minutes to get $20 worth of fuel,and then the nozzle failed to click off and diesel spewed all over my shoes,pants,and the ground..
I'm wondering if that pump had a clogged filter--or worse,the fuel had water in it..
I replaced the fuel filter about 4000 miles ago,and hate to buy another one at $25+ bucks if that isn't the problem..no one has one in stock locally either right now..
I was tempted to try draining it when I got home awhile ago,but I figured it best not to touch it--I need the thing to plow with,and it will be under 15 degrees for a few days starting tomorrow afternoon,so I'm not going to be out there dicking with it and possibly end up disabling it worse..
Any suggestions what it might be ?..my "guess" is its either the electric pump might be dead,or the fuel is crap...maybe the filter is clogging up...?
I hope it'll run tomorrow and be able to plow--wont be able to work on it until the middle of the week,when it might hit 40 again --and rain,of course..
.had enough discouragement for one day..
..pretty rare to hear that in January..it is pouring out right now,so there wont be any troubleshooting or repairs being done today..
