So since the interwebs is full of good and bad info ill ask a trusted source.
#1 will the shorter 6.5 injectors work on my 6.2 or do I want to swap heads on my j code diesel?
#2 Do I need to use the 6.5 injector lines with my swap?
#ay3 what are excessive egts with a turbo set up?
#4 If I keep stuff stock should I swap to 6.5 head gaskets? Ive read the 6.2 heads on some motors have sealing issues after this is done? I will need new head bolts correct?
#5 How do i block off the map port on my 6.5 upper intake?
