6.2 won't start
My phone is being temperamental and wont let me read the link, but with those pressures you'll be fine.
You can pressure bleed the filter before you try to crank it. If you have an adjustable regulator on your air compressor. Turn it down to 10 psi and blow air into the return line at the IP with the bleeder valve open. It will only take a minute to bleed if you don't have a blockage.
