So, some of you already know I pick up a 2019 Tahoe RST performance Premier this last week.
I've been told and then did some reading about 6.2s with AFM having issues with lifter and cam failures based primarily because of the AFM and possible bad oil choices. It seems to happen to most between the 100 and 150k mileage mark. I've even heard of some happening with as little as 39k.
Is this a common thing with these motors? Was there any engineering changes to help prevent this? Is there anything I can do now to help prevent it?
Thanks!
Thanks!
