K5dreamer
OK, so ill be testing my CDR valve today to make sure i really need one... but from the oil cloud on startup, the leaking valve cover gaskets, and the leaking oil pan gasket, im thinking its a safe bet.
the rub is that the CDR has been DISCONTINUED by chevy..... seems like kinda a prick move seeing as it causes so many problems when the sucker goes bad. i cant find one anywhere. i finally broke down and called penninsular engines, they build the marine 6.5L diesels, and they said they have them, but they are IN the valvecover........ mine is on a bracket mounted to the intake manifold OVER the valvecover..... so im not sure if its the right one. or if i will just need to buy the valvecovers as well and use the CDR they have.
Anyone here know of a place to buy CDR valves for the old M1009 Blazers with the 6.2L diesel??? im pullin my hair out on this one.
