6.2L diesel - injector fuel return lines missing piece
Overlander
Registered Member
Salem Oregon
There is a hose missing on the last injector on the driver side closest to the firewall - does anyone know if a hose goes on there or some kind of cap and if a hose is supposed to go there then where does it connect to?
I have looked all over for a diagram or something and can't find anything.
So I found a thread on another site about this and I guess there is supposed to be a plug on there... anyone know of something that could be used temporarily?
You should have 3 hoses going between the 4 injectors. A 4th hose ties into the main return line. Injectors at the back of the engine (#7 & #8) have a small cap that covers the unused return port. If that cap is missing a suprising amount of fuel will spray all of the engine compartment.
Makes a big mess.
Makes a big mess.
Yeah I had a puddle and then realized it was coming from that injector. What can I use to plug it that will stay on there though? I am in a bit of a time crunch so any ideas for something improvised would be great since the parts stores will be closing soon here. I don't have any random little hoses or tiny clamps handy.
If one of the other hoses is long enough. You could trim say about 1.5 inch piece off. Thread a small screw or bolt into it and push the other end on to the return port.
I did exactly that when the little plastic cap went missing on my 6.2's drivers side rear most injector..
I used TYGON 2 cycle weed whacker 1/8" fuel hose with a short 8-32" machine screw screwed into the hose to make a new block off cap..I also replaced a few of those return hoses with the same TYGON hose after they got cracked and brittle from old age and began peeing on the exhaust manifolds..was lucky it didn't burn the truck up..another piss poor design IMO..
Keep an eye on the hose if its the typical black stuff for non fuel injected engines,some of it doesn't stand up to diesel and will swell up or come off the barb fittings..
I used TYGON because it is able to withstand both gas & diesel fuel ,high temps,and it requires no clamps --it just pushes on (you may need to warm it up a little with a lighter flame),then it'll stay put with no clamps.
I've had it on my truck for over 3 years now..
I've also used Firestone air brake tubing with a 1/8" I.D. but it is stiff ,doesn't bend easily,and needs to be heated up to slip over a barb fitting..
It sucks trying to put those tiny squeeze clamps GM used on those return hoses,especially on the rearmost injectors ..that is the main reason I like TYGON hose,and it can be had at Lowe's or Home Depot,and most mower repair shops cheap...I keep a 5 foot length in my glove compartment "just in case",guy at the mower shop charged me $5 for it..
Been there, done that. I also had an injector with a nipple broken off. That one had the hole tapped and a bolt threaded in.
If you're on the road and can't find a cap, you can also tie the two dead ends together with a longer piece of hose.
My 87 6.2 liter on the return injector lines . The one closest to firewall on drivers side. Cap blew off. Truck sat for about six years. When I put a cap back on it , motor wants to due. If I leave cap off. Put a line on it , and let fuel from line run out into a fuel can , motor runs fine.
The engine runs with the cap off but will die if the cap is there? Your return line to the fuel tank is clogged most likely.
Both bank return lines feed to a metal pipe across the front of the engine. There is a return line on the radiator side of the injection pump that also feeds into the metal pipe. The passenger end of the pipe connects to a hose that runs down the passenger side frame rail to the fuel tank. I suggest removing the hose between the frame rail and the engine and try blowing low psi (10-15 psi) air into it toward the fuel tank with the fuel cap off. If no air moves then you get to drop the tank and figure out why.
