roydavenport
Registered Member
I have a 91 Suburban with the 6.2l diesel. I have been having some issues with the glow plugs and am looking for advise. The glow plug system on my truck (according to the Haynes manual) has a temperature inhibitor switch that supposedly tell the glow plugs not to come on if the engine temp is over 120 degrees. The problem is that even when the temp gets below 120 the glow plugs still don't come on unless the engine is completely cooled off. I only have this prblem in warmer weather. In cool weather the glow plugs always come on. I never have a problem in the morning or when the truck has been sitting for a good while. I only have problems when I've been driving around and let the truck sit for an hour or two before I try starting it again. Sometimes I have to let the engine crank a good while before the engine will start. Sometimes to the point that white smoke is coming from the exhaust before it will fire up. What I'd like to do is either locate this temperature inhibitor switch and replace it or figure out how I can bypass it altogether so that my glow plugs cycle everytime I start the engine like earlier models do. Please let me know if you have any suggestions on how to fix this. Thanks alot.
