Been coming back to this thread over and over and finally had the time to do it. I changed a few steps, I'm not sure how much it differs as I also have the earlier style spin on primary fuel filter/water seperator, and the secondary that is mounted behind and on the intake manifold. It appears from the pics in the write up that it's a CUCV. Same principle in my video can be done on any 6.2, only thing that differs is locations.
I thought the same as K10 KRAWLER did, why not just pull the cleaning agent directly through the lift pump, and return the excess through the return lines. Made it simple, re-route two hoses and done.
Enjoy!
I'll report my findings later as I still haven't finished connecting it back up and bled the system.
Update: So I bled it and took it out to fill up. Can't say I noticed a power increase, I probably wouldn't regardless with a 700r4/208/3.08/33s, I'm under geared. At higher rpms foot to the floor on a 55mph road was a whole lot better. Before it'd kinda sputter once the rpms got up there if I did that. It does idle and cruise more smoothly. Filled up the tank, put 20.4 gallons in, came out to 13.2mpg. Which isn't a lot, especially for a diesel, but that's all city driving, no highway, plus a day and a half of crawling at the park which I'm sure is really what contributed to the low mpg. Plus the filter(s) change, bleeding it, letting it idle. Last time I filled it up was a good 2 + weeks ago, I don't drive it that much. Wish I wrote down how many actual miles I drove, but my mpg app doesn't show old odometer readings. I'll post another update next time I fill up to see if there's a difference after the purge.
Update: Aug 4 - 16.9mpg city/rural type driving. Interested to see what HWY mileage will be, but I never drive anywhere far.
