I've got an 85 k30 that I'm tracking down electrical crap. And to throw a wrench in things, I added a big truck gauge cluster with tach. Switched the oil pressure and clock from original gauges. After a new headlight switch, fixing some frayed wires, and misc problems things start working. They all seem to function except for the tach. I don't know where to find tach signal first off but the fuel gauge is good so far
THEN... I leave the headlight switch on and turn the truck off. Pull the key out of the ignition and the truck doesn't turn off. It remains running with the lights on. I turn the lights off and it kills the truck. I am not sure how these things are related and it's late. I packed it up and came inside.
What the hell is happening and where can I find a wiring diagram? Brochures.slosh.com does not feature the diesel wiring and this is a civilian truck so not sure if the cucv stuff is applicable either.
TL;DR
Stoked about the tach, not sure where to get signal.
Head light switch turns ignition off.
TL;DR
