6.2L rattle/tinkle noise after start up
AJMBLAZER
Better to be lucky than good.
Staff member
Moderator
Paducah, KY
A while back when I first got The Blazer I was hearing a sorta whir noise when I started it up. The thought on here was that either the starter was dying or needed shimming.
Haven't done anything about it but it's doing fine anyways. No changes and it starts every time. Life's getting in the way ya know?
Anyways, while I was downstate my much more engine and drivetrain knowledgeable friend heard it and thought it might be cracking around the flywheel allowing it to wobble as it spun? Does this sound right? He said it was common with them?
The guy knows a lot of stuff, and has rebuilt many SBC's, but I just want to make sure he's not confusing SBC's and the 6.2L like many want to do.
Sorta wishing I had bought that 6.2L 700R4 flywheel from kennyw a year or so ago.:doah:
It is common for the flexplates to crack and have the center break out (mostly from poor installation or something coming loose)... However it makes that noise 100% of the time and not just at startup. And it is a horrible noise that jumps out at you from a block away.
Hrmmmm. Well, they did do the transmission repair last year...
...I can't hear it inside other than at idle so it's hard for me to say if it continues or not.
How would one check for this...remove the inspection cover and feel for cracks or start it and watch it spin?
With the motor OFF, remove the inspection cover and see if you can wiggle the flexplate gear at all by hand, then try a large screwdriver. You should not be able to move it around either way.
kennyw;2566864 .....it is a horrible noise that jumps out at you from a block away. [/quote said:
My 85' 6.2 made this noise quite a few times, only at start up though, it got to the point where i prayed it wouldn't make this sound cause people were around :blush:. Problem was that i had a broken starter bolt and NO rear support bracket. I fixed the broken off starter bolt and the broken off bolt in the block that holds the support bracket on, to only have this "grind" noise happen every so often, checked bolts, bracket and everything was fine. Pulled the starter and had it rebuilt, which was well needed, figured the bendix wasn't shooting out fast enough to mesh well with the flexplate. It helped greatly, about a month later it made that terrible noise two more times within a week, a couple days later i went to start it, turn the key and nothin, come to find out my pos. battery cable on one battery was really loose (threads in the side post were stripped) put an adapter on to go to the top post and never had the "grind" noise happen again. I think the loose battery cable wasn't sending the full amount of voltage to the starter and not letting the starter engage quick enough. Just thought i'd share my starter problems and experience with the ear screeching noise. :doah:
