07 grizzly700 BE
Registered Member
So i have a 85 suburban 6.2l, and when i first got it it barely started in cold weather. So i changed the glowplugs to 60G's, the glow plug controller, cold weather motor oil (5w30), and the antifreeze.
But now it still starts very rough, except for when it is hooked up to the block heater.
So i checked the battery's and when i turn the key and the glowplugs start cycling, the voltage drops to 11v. Could it be the battery not having enough power to heat the glowplugs and turn the starter?( because the starter doesn't turn fast at all). Or could it be that the new 60G don't warm up long enough because of the stock controller? The controller is the thing with 2 terminals and 4 pins right? located behind the airfilter.
It does start, but it takes very long, and when it does, it runs rough and has A LOT of smoke.( white blueish)
Sorry for the long post, and thanks in advance guys,
Matt
Matt
