My '82 K2500 6.2 with a TH400 never did shift right with the VRV valve hooked up properly,I think it was fubared or cracked --I went to a local tranny guy and he suggested I run the vacuum line to the modulator right to the vaccuum pump,and then turn the adjustment screw inside the modulators hose nipple all the way in till it gently seats,then back off about 1/4 turn..........................................................................................................................................................................................................So far its shifting OK,that was 9 years ago and about 100 snowstorms ago!..it used to hang in second gear way too long and refuse to upshift till I hit 40-50 mph into third,and if you happened to let off the pedal while it was still in second,it would feel like you shifted it into neutral...when it did finally upshift to third gear in went in harsh too...now it shifts 1-2-3 OK,maybe a bit too "early" into third for my preference,if I want it to stay in second longer I just downshift it manually...its held up good so far and I have beaten it mercilessly plowing..supposedly the trans was rebuilt shortly before I bought the truck,whether thats truth or fiction,I dont know........................................................................................................................................................................................................I couldn't find a good used VRV valve or a new one for less than 100 bucks anywhere,and I did think about using the cable operated modulator they put on TH400's with supercharged engines,but those were well out of my budget range too...but one probably would work good once its dialed in right...
