6.2l to 350 swap
I've done it, but it was probably 6 years ago-I'll try and help with what I can remember....You will need to change the radiator or use a flex hose on the top line, the outlet is further toward the outside than a standard sb radiator. I seem to remember most of the electrical lines needed to be shortened (water/oil temp), and you need to add an HEI pigtail to the injector pump wire, then you can use this for your distributor power wire. I switched the torque converter as well. I THINK I had to modify the fuel lines somewhat, since I took the fuel filter off of the firewall, but I don't recall exactly what I did. Sorry that isn't a ton of help, if I think of something else I'll post it.
