I have a stock 2000, 6.5 with 195000 on the clock. I need to do some preventative maintenance to the motor. Nothing really wrong with how it's running, but I think I'm running on borrowed time.
So the list of things I plan on changing....
Injectors.
Glow plugs.
Oil pressure switch.
Lift pump.
Sock filter in tank.
Harmonic balancer.
Leaking oil lines.
Replaced in the last 5000 miles...
The PDM.
Crankcase regulator valve.
Is there anything I'm missing when it comes to common problem part?
Injectors.
Glow plugs.
Lift pump.
Harmonic balancer.
Leaking oil lines.
The PDM.
