6.5 marine injectors
If you're talking about the '86 CUCV in your sig, they should fit. Early 6.2 heads (82-83?) had different threads for the injectors. Unless older heads have been swapped in at some point, which is unlikely . . .
You may want your injector pump to be built to match those injectors while your at it.
