6.5 turbo onto a cucv 6.2
84CUCV
3/4 ton status
NJ for now
well, never seen one. found someone that is taking the truck down for parts. so i would need every little thing for it right? should go right on a 6.2 i would think. any help would be great thanks
I called my part store and the guy said to look on line for guages cuz I can get them cheeper then even he gets them from the suplier.
Now I got to figure out what brand.
you need to grab the turbo, manifold, intake hat, and tubing that goes between the two. also grab the tubing for the CDR valve. Oil supply line, drain line and cover that it goes into on the block. the crossover pipe may or may not fit, depending on a few variables. if it doesnt fit it will be close and you can modify it ot make it work.
On my 6.2 can I use the oil cooler line as a suply line for the turbo?
thanks guys, ccatlett1984, i will get back to you soon about the other 6.5 and 60 hubs. still trying to find them in all my junk.
