Sold 6.5 Turbocharger kit
campfire
Adventure is out there!
Northwoods Wisconsin / da U.P.
Turbocharger kit from a 6.5TD. Have had this sitting for 3 or 4 years and am going another direction.
Included are a GM-3 turbine, mechanical wastegate controller, exhaust manifold, and both upper and lower intakes. In order to install this on an NA engine you'll need to run oil lines and rework the exhaust and air cleaner.
$300 plus shipping.
20170621_193502.jpg 20170621_193509.jpg 20170621_193522.jpg 20170621_193531.jpg 20170621_193609.jpg
Bump. This spinney thing is still sitting in a lonely box...
I know that it doesn't work with a square with a/c, and probably why you didn't use it.
How much interference with the a/c box is there?
Can it be modified a bit and still work?
The turbine exhaust outlet can be modified to route around (though close to) to the AC box. A box of 3” mandrel bands and a patient weekend would get it done.
David
