thanks so much, definatly putting together my list. and thanks for pointing out ill need the turbo CDR, i was getting ready to buy one for my truck anyway, so its nice not to blow the 70 bucks needlessly.
and a few questions that have popped up. mainly regarding the oil to the turbo.
is there a reason i cant return the oil to the valve cover with the CDR on it? if thats a problem, could i run the oil return line to the other valve cover? or maybe the oil fill tube?
regarding the oil supply, you mention a nipple that is there for the oil line, is that there on the older 6.2L engines? or will i need to drill, tap, and install one? if its there, whereabouts is it, and what am i looking for?
and wise advice on the balancer, i might as well be looking for one of those in good shape too until i can buy a new one. mine has started to concern me and i know those are the widow makers of the 6.2 engines. the main girdle is also good advice, but i hadnt heard about it until you mentioned it. do you know who makes it? Ill also look into the pryometer and boost guage, im sure i can find some place to put them, im in the process of putting together a list of parts to turn my "idiot lights" into guages. oil pressure, two voltmeters, then putting my coolant temp guage where the old voltmeter used to be, so ill have two spots to put the boost and pyrometer guages.
The engine is not currently apart. but im definatly thinking with the possible tranny swap coming up, and installing a turbo, and probly doing a rebuilt pump and injectors, it might be what i wind up doing. Just completely freshen up the engine, new bearings, rings, head gaskets, and maybe a set of ARP studs for the heads and main caps. the other weak part of these engines are head gasket failures, especially with boost, makes sense to have all the insurance i can get right? maybe port and polish the heads a little bit while they are off and install some megaflo valves.
the reason i asked about the cam swap, is i saw a used 6.5L cam for around 35 bucks, and seeing as its a roller cam, i dont feel to concerned about putting it in the truck. So i was just wondering if there was a benifit to the cam. i cant find the specs anywhere on the internet, so i cant tell if there is a signifigant difference.
