pseudomike
Ok guys, i picked up a 1997 K2500 (94k miles) with a 6.5TD in it from a friend for a good price. The truck will start and run but sounded like it was skipping and was sending enough raw fuel and white smoke out the back to clear skeeters in a 10 mile radius. So....after doing a little research I decided it was probably a bad injector so i replaced all 8 with some Bosch units. Fired the truck back up, MUCH less smoke....but still missing and running rough.....and once it gets warm it has a knock resembling a wrist pin or valve train problem that gets worse with engine speed. Now the kicker, if I shut the truck off once it's warm it won't start until it cools off.
So I did some more research which led me to check the balancer and the flex plate...systems check here so i am scratching my head and wondering if I should just locate another motor.
I am guessing the not starting once warm is a worn IP. Is it possible that the IP will cause all this racket? It is loud, coming from DS. Also, some other observations....warm it has maybe 35 pounds of oil pressure, the breather has a steady stream of white smoke etc. which to me indicates blow by, the intake side of the turbo has raw fuel in it but I think it may be coming from the breather. The turbo itself is good.
I have a good low mileage 6.2 in the garage....can I simply swap all the 6.5 stuff onto it and be on my way? Will there be a noticeable loss of power.
Thanks,
mike
Thanks,
mike
