6 bolt rim interchange
ciffer
Southeast MN
I searched and couldn't find anything.
What years interchange for use on these trucks with 10 bolt 6 lugs.
I'm not sure if I understand your question, but if you are asking if there is a difference in the 6 lug bolt pattern, there isn't. All (GM) 6 lug wheels are the same lug spacing, wheel width and backspacing has varied, but the actual bolt pattern has remained the same.
This may be a stupid question, can new rims be used on a small hub truck or are the wheels hub centric?
newer IFS style rims CANNOT be used on any solid axle chevy. But, i believe they can be used on the 2wd 6 lug trucks, but not 100% sure. But the newer 6 lug rims will not fit any earlier 6 lug 4x4.
And to the comment above, i ment to put stock rims, you can get anything you want aftermarket if you have the money and someone who wants your money.
