6 inch reverse shackle flip
justcawzintrouble
Registered Member
Cairo, Georgia
On my K5 I put a 6 inch reverse shackle flip and took out the 6 inch blocks from the axles. It seems to me that the driveshaft is too long and is now completely in the transfer case??? Has anyone else had this problem and should I be concerned as I have already had to replace my shaft seal after wheelin once.
ha mine did the same, but im running blocks too, so i flipped those the wrong way and that helped out.
