6" lift
bigwalleye
Portland
On a 76 blazer what do I need to change in the front to run a 6" lift spring is it just the ds length or do you have to do a cut and turn to help out the pinon angle?
you have to worry about steering, brakes, springs, shocks, and driveshaft, i'm not sure if you should shim the axle, someone here will tell ya though
