6 lug 9.5 semi Float 14 bolt
63chevyll
Colorado Springs
Has the correct perches and shock mounts to fit under a 1973-87 1/2 ton or 3/4 ton K5, Truck or suburban.
Will aslo fit K5 and burb to 91
3.73 gears, and a gov lock posi.
Very clean inside and out.
Complete drum to drum. Only thing missing is e brake cables.
$450 local preferred
Is this the same wms width as the 4x4 rear end that came stock in these vehicles? Can the original brake cables be swapped over or does it require cables unique to the SF 14 bolt? Can this be used with stock type 15 inch rims? Thanks!
Im pretty sure the brake cables can be switched over.
The yoke is the same as 10 bolt
15 inch wheels ok
