6 pin conectors
pomai
Oahu, Hawaii
Could someone tell me what these 6 pin connectors are for?
Thanks, Ed
that is the plug that runs to the Data Link Connector, check engine light and has a constant hot wire in it.
I removed the computer and harness. I see that the end sticking out of the glove box goes towards the fuse box location. Should I remove that part also?
Thank you for your help,
Ed.
brown/white wire is the check engine signal from the ECM
orange wire is goes to the ALDL
white and black wire goes to the ALDL
brown wire sends the VSS signal to the ECM
black and white wire is a ground
orange and black wire sends the park/neutral signal to the ECM
Thank you very much, that was a lot of help.
