spastik monkey
So I keep throwing the low tps voltage code. I go out to adjust the tps. I'm reading 6 volts as a reference signal. With and without the sensor plugged in. Reading 12.74 volts at battery. at one point it dropped to 5.12 volts then went back to 6. What would cause this? I know the ECM puts out the ref signal
