60 axle joints. what do you use? Poll
what D60 axle joint do you use
  • Total voters
    59
If you weld the caps to the ears it makes the cap a structural component. (not just little tack welds to keep the cap from spinning) But ya, replacing u-joints is pretty much out of the question, but they will last much longer if they are welded and serviced properly.
Basically what bgreen said. Especially with a Spicer shaft, the ears will deform slightly under heavy loads and let the caps spin. If everything is welded it helps keep it from doing this.
Hey There,
I used Spicer SPL-55-3x non greasable units. These u-joints are very stoudt and I'm sure will hold up to everything I can dish out! If you're lookin' to replace, I'd go with these!
Manny
koldsimer said:
Finally! I had heard about this but hadn't seen the actual test results. Thanks for the link man! Glad I got longfields!
No problem...I was glancing at your signature...your Blazer seems quite similar to my Ford....other than your hydro steering...and the obvious difference in wheelbase. :D
Roy
