60x40x16 Shop Build “Tow Strap Garage”
Installed the walk through door along with the door handle and coded deadbolt. Still need to do a final seal around the door frame, but everything is secured now.
I then relocated the boat to the side and snuck everything in that is getting worked on shortly. A little on the dark side, but secured and out of the elements now.
And Im sure there is a lot of “shop” equipment to go in there too?
Curious on the entry door, is it pine framing?
The last two entry doors I bought have composite lower 16” to prevent rot out from being exposed to rain and snow. Seems I can’t keep them weatherproof with paint, and so far these two have held up well (8yrs now).
It’s hard to tell from the picture, but there is a 20x20 area behind the K5’s that is currently taken up by a lot of random “garage stuff” that needs organized and relocated within the shop. There is also a large pile of scrap metal between the boat and the Duramax.
Yes the door framing is pine. I looked at Menards, Lowe’s, Home Depot and none of them carry composite frames in stock which blew my mind. The price was double for composite frames, but I was willing to pay the difference as I know it would have held up longer in the end. So I’m sure at some point in the future I’ll have to hang another door. All 3 said they could special order them, but that would have made the door almost $700 vs the $300 we paid. It is a metal door, and the frame is very well made with built in metal brackets around the hinges and latches.
What really helps is wrapping it with vinyl or aluminum, but you might need a brake to do it, and you have to seal the bottom so water doesn't come in off the sill. When nothing else is planned, I try to paint the bottom edges with epoxy. You can paint every so many years, but I suspect the problem is water coming up the end grain of those side boards.
