63" leaf spring question
dheavychevy38
Algonquin,illinois
So I aquired a 94 k3500 and have a busted main leaf in the rear. I have a 02 rear with springs. After digging around it seems that the springs from the 02 don't use the same bushings as the 94. Is this true ? Will the 94 shackle work with the 02 spring ? Thanks in advance
If i recall the 1 end they jumped up the bolt size over the older body style . So you should just be able to drill out the hanger hole and shackle hole and use them .
And fyi : there 64" springs . 32 eye to center x2 .
