Any body set up a set on a suburban i have seen plenty on k5 and trucksbut not aon a sub or am i missing a thread. i am thinking of running them and would like the axle to go back so i can get more up travel and not get into the door. They are supost to move the axle 6 inches to the rear sound's good and should clear nice. Then i will only need to stretch the wheel opening rear ward sort of making it loke like a tahoe.there should be enough room to move the tank to clear and so forth.
Only problem is with running 56 in front and haveing the axle moved forward my wheel base is going to be crazy long.
