64 inch spring swap?????????????????????????s
I just got done doing 64" spring swap in my 1983 K5. I'm running 5" lift 88-98 1/2 ton springs from Tuff Country. I got them really cheap brand new from another guys project he never finished. I cut up my front hanger and boxed it all in and welded to the frame right up against the cab mount and as high as I could go and still get the spring eye bolt in. T&A Automotive offers a bolt on front hanger for K5s to do 64" swap now. I was going to do T&A Automotive's no lift shackle flip in the rear but I ran into Stephen from ORD at Jeep safari vendor show and he advised on standard tension shackle but go longer to get the truck lower and also allow more shackle swing than a shackle flip. I ended up moving the stock rear hanger back to where it looked good and welded it to the frame. I used a 6" ORD heavy duty shackle with greaseable bushings all around on rear. I also added a 1.5" block just because I currently have 6" lift on the front. I will probably remove the block after I do a 52" front spring swap in the future. I'm running a 14 bff and it clears stock gas tank setup and sits about 2" rear of where it should so I had to trim my fenders. I'm running 315/75r16 bfg tires on 16x7 steel wheels for now until I do weld on beadlocks and I can stuff them all the way to almost touch inner fender. I still need to do bumpstops and rear shocks but I currently have only test drove it and I get 10" of rear travel with clamps still on the springs. 5" up and 5" down. I will prob need a traction bar but I have a gutless 6.2L diesel. Hope this helps.
Heck yeah, this is even before all my pictures of my swap! :haha:
I will get some as soon asI can. I just shot that one up off my phone. I need to start a build thread. I just upgraded to premium the other day.
Here's some more poser shots, I had just got it driveable and ran it out to a wash by my house and maxed it out to see what it would do since I have open diffs.
Currently I have brand new 6" lift 1969 3/4 ton suburban springs from tuff country and ORD heavy duty shackles. No sway bar. They are actually shorter than 73-87 front springs and I moved the rear upper shackle hanger forward using directions in a tech article on ck5 about a 52" spring swap. That way I can remove them and modify front hangers and do a 52" spring swap later. It moved the front axle forward maybe 2". It measures 2 1/2" up travel and 2 1/2" down travel at the shocks.
I bought it in '07 and it was originally going to be a big nice cruise around truck because it is 100% rust free. I had 8" rear springs and 1 1/2" blocks on it before and then moved to Moab a year and a half ago and decided to redesign it to actually work off road. I'm hoping to get it done soon and start wheelin.
Holy old thread batman. I happened to log in today because it's miserably cold outside and saw I was flagged by @Ricky Bobby. My big dumb mud truck is still sitting out in the woods rotting away under a tarp... largely been sitting for a decade now. It looks like people are still doing the same stuff the same way which is pretty refreshing.
