royjones
Trucker upper
heck
Heck just put them own and go rock humpin 10-4 lol
This is not true.If you were able to set up this test:
A long strip of spring steel.
Cut a 64" strip and a 52" strip from the SAME material
apply a given torque to each
The 64" strip will deform less.
You say that Wikipedia is a poor reference, but you completely trust the sales-pitch from a Ford employee in a commercial-video on youtubeAnd if you're still too stubborn to listen to me, watch the darn video I posted. It's like the first statement he makes. If you don't believe a major diesel truck manufacturer, well then explaining this is a lost cause.
Well said!Nice 64" swap write-up
But when it comes to physics, I advice you to redo your home-work
This is not true.
I'm not saying he's lying, but I think he simplified it some...
I think he means that they can make it more resistant to wrap indirectly because of the length, but not due to the length itself.
A longer spring IS softer
But because it is softer, you CAN add more leaves and make it wider/thicker without making it superstiff.
And it's the stiffness close to the axle that counts when we want to avoid wrap.
Since the rotating force from the axle (torque) gets less and less the longer from the centerpin.
Another thing I'd like to point out when it comes to eliminating axle-wrap is the stock staggered shock mounts.
Many people tend to rearrange their shocks inwards,
but I think that can increase the risk for axle-wrap.
In my experience you don't need superlong shocks in the rear, you can get a decent flex with 11-12" shocks, and thats possible with stock shock-mounts.
I hope this made at least some sense, English isn't my native language![]()
I love it when a completely good post turns into a vagina measuring contest. Keep it up boys , its great entertainment![]()
