i've seen the dirt track guys take all the vacuum advance stuff out of the dizzy,..then they fully advance the dizzy(where the bars that held the springs and stuff) are in a ''X'' instead of flush w/ each other...then mig tack it on both sides of the >X< to lock it fully advanced, then tune for highest vacuum ....they swear it is quicker out of the corners,..
so last october at the tri-county fair demo derby, i helped build 3 or 4 cars and started out doing the pinned dizzy on 1 car,..and it was such a noticeable difference,...the other car owner/drivers wanted me to ''do'' their car like the 1st one...i had used a screw to lock it, incase it didn't help off the line as anticipated, i could go back stock,...i wound up welding it & doing that little trick to every car i came across that was a friend...needless to say i did alot of dizzys in the pit area
i also have a locked dizzy, for the mud truck & it does do away w/ the vehical's lack of throttle response, it bleeps when you pin the throttle, not BbOooooGggggg..rrreeeevvvvvvvv
