68 SB Roller Frame
p0ps45
Rancho Cordova, Ca
1968 1/2 ton trailing arm sb roller frame for sale. Front disk brakes, pwr steering, manual brakes. No parking brake cables. Also included there is a 350/ 3sp column shift trans., the engine ran before parking, but probably needs work. Trans needs at least a rear seal but otherwise worked.
No intake manifold/carb/air cleaner. M/T Thompson valve covers included. All other accessories complete, including ram horn ex. manifolds. I also have the 3 sp. column, shift linkage and the clutch parts. I have a set of black center caps for the 5 lug rims. One of the chrome ones is missing. Tires ok condition but should be replaced. Also have the radiator, heater core & in cab gas tank, fold down spring type seat, some broken springs,upholstery shot.
I do not want to part this out as I really don't have time. Delivery if you set it up. I will deliver within 50 miles of Sacramento, you pay for trailer rental & gas Looking to get $850 for the complete set up.
