69' Camaro
Should be
Font:
17x8.5 +30
Rear:
17x9.5 +20
ESR Bolt pattern is 5x120 which does fit close enough. Never had issues.
Did you have to run any spacers? Any issues with rubbing? Did you have to roll fenders? I see that ESR now makes wheels with a 120.65mm bolt pattern which should be perfect.
Yes I did run spacers front and rear. No rub except when the rear was articulated and the rear tire would barely rub on the inside of the rear tub. No fender rub.
Good chart for wheel sizing. I tried to match the wheel offset and spacer to these specs.
You never forget your first . Bought it for $4,300 in 1993. Got it painted in August ‘97 and rear ended/totaled 3mos later. 79683191-4678-42E5-B7E5-EAEDBCF04F3C.jpeg
