6in lift springs and shocks
mtnman210
Northridge, Ca
I have a full set of 6inch lift springs from a 77 Chevy Blazer. They are skyjackers soft ride springs. They should fit all chevys in that era. Buyer is responsible for checking if compatible with their own truck.
Asking $400
Also have a set of 4 procomp shocks. They have some minor dings but all straight shafts. They measure 35.5" extended and 20.5" collapsed
These shocks were NOT used in the STOCK mounting location with the springs above.
asking $50
Located in Thousand Oaks, Ca
Sent you a PM the other day. Haven't heard from you yet.
I do but not often. I'll check the calendar and see if there's anytime I'll be that direction or atleast might be able to get the parts that direction.
I know a lot of these kits have 6" springs up front but come with 4" springs out back. I was wondering if this is the case? Are they 52's or 56's?
I'll double check but I'm almost positive they are 52" rears. They are both 6" springs, no blocks and the truck sat level.
They rode and flexed pretty good for a lift spring. I don't know about miles, they were on a dedicated trail rig. So they only saw trail miles.
Would you sell just the fronts? If so, how much shipped to a business at 67337?
I guess while you're at it, quote it as just the fronts and both sets.
Did you sell all the springs or just the fronts? I'd be interested in the rear springs if you still have them and if they're part #CR16S....No shipping needed. I'm local and in 1000 oaks often.
