Can y'all skool me on these? Good, bad, the ugly...
That is not from the transmission but the drive by wire.I'll tag along with ya BigRay. The factory one in my 6.0/6L80 van leads me to believe they are wonky but I know in factory form they can be. No such thing as "crawling" or using both feet in that van. Felt more like an ON/OFF switch.
Ditch the TC and reprogram the lock up
. As stated, the trans is good, but hampered by stock calibration. Using an aftermarket controller (presumably in conjunction with the internal controller), that problem can be eliminated. It's rated for 550lb-ft, but it's likely that's taking torque management into account (i.e. torque is reduced during shifts). Since you won't have DoD, much of the wear on the torque converter is eliminated (it unlocks the converter on every cycle in/out of 4-cyl mode).That's why don't care for the GMT800 and up trucks.
They won't do what you want without you having to fall in line.
Such as having to smash the brake to shift out of park, or having to unlock the door manually after putting it in park,
Or just having automatic locks in the first place.
I want a truck, not a nanny.
