700/241 to 400/208 swap, what hicups do I need to watch for?
Kyle89K5
OKLAHOMA
Title say's it all. What little something do I need to keep an eye out on? I want this to be as quick and painless as humanly possible /forums/images/graemlins/grin.gif
Also, I'm looking at a 400/208 from a CUCV, besides the convertor, what else will make me have a bad day...
Anyone?
TIA
KP
The TH400 will need a switch under the go pedal for the kickdown.
Check the crossmember, make sure you have one that will work with the 400/208.
You'll need a vacuum source for the modulator on the TH400.
[ QUOTE ]
[/ QUOTE ]
can I do a cable from the TBI unit for the kickdown?
I've got an old 2x4 laying in the garage from a woodworking project, that'll fix the crossmember issue
How much vacuum is required? I figure to tap off any old post on the intake, BUT...
Can't use the cable, the 400 has a switch on it (no provision for a cable).
Not sure about where to get the vacuum from, Mine always had a manual v/b so I never had to deal with the kickdown or modulator issues.
You could do the v/b too, you know. I got a reverse pattern unit, I always liked having 1st and reverse next to each other instead of being 4 shift points apart. Things that make you go, hmmm... /forums/images/graemlins/thinking.gif
No, there is no place to hook a cable so you cannot use a cable to "kick down" a TH 400. If you don't care about the kickdown, you don't need it though.
You simply need to hook up a vacuum line. There isn't a measurement of, "how much" vacuum, just hook it up.
[ QUOTE ]
[/ QUOTE ]
That's my plan, but budget says it will work like a normal tranny till I get the new shifter and VB in. That is unless some kind soul wants to donate to the OFN project blazer /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
Tim,
Didn't think so, but hell, I've been suprised before by items *not getting enough vacuum* Just like to make sure before the thing stomps it's own dong when I hit the gas /forums/images/graemlins/eek.gif
Use direct manifold vacume. Usually off a tree on the back of the intake, but can also come from plenum or base of carb... Just make sure it's not ported above the butterflies.
[ QUOTE ]
[/ QUOTE ]
/forums/images/graemlins/waytogo.gif
[ QUOTE ]
[/ QUOTE ]
That's what I was looking for on that one /forums/images/graemlins/laugh.gif
Any you should know by now, I'm running FI, no STEEENKIN carb on my rig /forums/images/graemlins/histerical.gif
